Erazer bandit p20 md3d34510 b660h7-m20 can't update bios
20 RÉPONSES 20
Mrdw
Message 1 sur 21
1 527 Visites
Message 1 sur 21
1 527 Visites
I just purchased the pc from currys and I can't see any way to update the bios for the motherboard. I can get in the bios but it looks like something from win95 and the only videos I can see on yt about this type of bios are from 13 years ago.
Has anyone else had the same issue and found a solution?
I've been in the device manager and tried to update firmware from there but no cigar.
20 RÉPONSES 20
RAZZ
Message 2 sur 21
861 Visites
Message 2 sur 21
861 Visites
Hi @Mrdw
are you able to provide the MSN (8 digits) of the unit and the current BIOS version, so we can look into this further.
Thanks
Mrdw
Message 3 sur 21
836 Visites
Message 3 sur 21
836 Visites
MSN: 10025150
Bios version B660H7WOX.206
On system info it says 1.0
Bios date: 01/12/23
RAZZ
Message 4 sur 21
771 Visites
Message 4 sur 21
771 Visites
Hi @Mrdw
Version 2.12 is currently under evaluation, but I can provide V 2.09: https://cdn.medion.com/downloads/software/00_Bios_b660h7-m20_v2.zip
-Unzip the file to a location on your SSD/HDD and execute the file WFH.bat by right clicking it and run it as admin
Important: MEDION AG accepts no liability whatsoever for any data loss or hardware or software errors that occur as a result of the update. The customer acknowledges this when performing the update.
thanks
Mrdw
Message 5 sur 21
759 Visites
Message 5 sur 21
759 Visites
Did exactly what you said, nothing happened.
Bios is still on same version.
RAZZ
Message 6 sur 21
747 Visites
Message 6 sur 21
747 Visites
Hi @Mrdw
Thanks for this update, I will look into this and get back to you
RAZZ
Message 7 sur 21
611 Visites
Message 7 sur 21
611 Visites
hi @Mrdw
please follow instruction from the video
https://cdn.medion.com/downloads/videos/IMG_4693_bios_ecs_b660h7.MP4
We suggest you start the console as Admin and execute the WFH.bat there. The VMD Settings generally are set as ‘Enabled’ by default after the BIOS.
This must be observed, otherwise a blue screen will appear.
thanks
Mrdw
Message 8 sur 21
602 Visites
Message 8 sur 21
602 Visites
I can't tell what was typed into cmd on this video..this will deffo update my bios right?
Vince
Message 9 sur 21
461 Visites
Message 9 sur 21
461 Visites
Mrdw
Message 10 sur 21
448 Visites
Message 10 sur 21
448 Visites
There no text in your reply
20 RÉPONSES 20
