BIOS Update for ERAZER X15807 (URGENTLY REQUIRED)
17 REPLIES 17
shakeeb_rao
Sleeper
Message 1 of 18
Message 1 of 18
Well, i have been noticing some power management issues with my keyboard for a very long time, some lights of keys of keyboard gets on whenever i plug in the laptop. But now, it has come to the situation that i cannot use my keyboard with the RGB lights on. Windows also do shows device descriptor Request failed for the port, means windows are disabling it due to improper behaviour from keyboard. Also, i cannot control my keyboard using control centre.
Secondly, it takes too much time to boot up and get to the home screen of windows. Whenever i press power button, for the 10 seconds, there is no response and after that, erazer logo shows up on laptop, which is clearly outdated BIOS. Kindly do help me.
Thanks.
laptop Details:
MD 61597
Erazer X15807
MSN 30027173
17 REPLIES 17
Message 11 of 18
Message 11 of 18
@shakeeb_rao
 No, sorry,  I can not. I am just an advanced User.
For the Bios Version.  N.1.52  ask   a Moderator eg. @Major_ToM .By calling his name he is informed  already.
Just ask him kindly, as well as I do.
Major, please help @shakeeb_rao .
Bye, daddle
shakeeb_rao
Sleeper
Message 12 of 18
Message 12 of 18
@Major_ToM I hope so you are fine. I am stuck at a BIOS bug which is too much complicated to solve. I want to restore my factory default version which is N.1.52, other details are mentioned in the first 5 replies. I want a link of BIOS file.
Thanks
shakeeb_rao
Sleeper
Message 13 of 18
Message 13 of 18
Mastermind
Message 14 of 18
Message 14 of 18
Hi @shakeeb_rao ,
I zipped the WU  and alternatively the FW Update version 1.52 of the updated to be downloaded here.
@RAZZ .. & @Igor28 I´m taking over 😉
Cheers
Message 15 of 18
Message 15 of 18
@Major_ToM
Hi danke für deine Mühe. Im Link aber ist ein kleiner Fehler
Er lautet. http://00_bios_x17803_v152.zip/
damit lässt sich nichts downloaden. 🙂
Gruß, daddle
shakeeb_rao
Sleeper
Message 16 of 18
Message 16 of 18
Thanks for the response but i am not able to download anything from the mentioned site.
Message 17 of 18
Message 17 of 18
Hi @shakeeb_rao
try that
https://cdn.medion.com/downloads/software/00_Bios_x17803_v152.zip
bye Fishtown
shakeeb_rao
Sleeper
Message 18 of 18
Message 18 of 18
it has started downloading. Thanks
17 REPLIES 17
