le 21.09.2022 10:23
le 21.09.2022 10:23
Hi everyone,
bought a MEDION Notebook E6247 on Amazon but the Notebook is missing power supply. So far I found out this needs a 65W 3,42A 19V charger but I'm having troubles finding the dimensions of the power supply's pin that goes into the Notebook.
Can someone please help with that info or even better send a link to a compatible power supply I can buy on Amazon or somewhere else?
Would really appreciate your help on this matter.
Thank you!
23.09.2022 17:50 - modifié 23.09.2022 20:18
Sorry to hear that.
May be you can go into an electronic supplier shop and test different plugs. The one which fits tells you the exact measurements, and you could connect it to the wires of the Power Supply you had bought.
But I wonder there came no matching plug with the power supply.? Is the 3.5 mm plug too thick? Or the hole for the pin too small?
le 27.09.2022 09:26
le 27.09.2022 09:26
@daddle The hole in the notebook is slightly larger than the 3.5 outer plug. And feels like the 1.35 in the plug is too small for the pin into the hole.
I think I'm sending this back to Amazon, this is getting too complicated and Medion never got back to me.
Thanks for your help and patience!!!
le 27.09.2022 10:09
le 27.09.2022 23:26
le 27.09.2022 23:26
hello @bublik
Nice that you found a suitable power supply.
but that also says that the information stored in the database is not correct.
hello @Andi (moderator) can you please verify that. thanks
E6247 / MSN30031867
PSUP Chicony A18-065N3A P5 3 Pin 65W / MSN40073024
DC plug dimension is 3.5*1.35*11mm in = + out = -
however, according to @bublik information it is 5.5*2.5
bye Fishtown
28.09.2022 07:56 - modifié 28.09.2022 08:00
Hello everyone.
That is correct.
The connector dimensions are 5.5mm x 2.5mm x 11mm.
@bublik schrieb:
I found this one for exemple, but nor sure the charger's pin has compatible dimensions, 2.5/5.5, would that work? Thank you
https://www.amazon.it/LEICKE-Alimentatore-Medion-Notebook-KSAFI1900342T1M2/dp/B0028PUWA8/ref=sr_1_2?...
Yes, that works.
@daddle schrieb:
Or you trust us, or leave it. We can not give you a link to the Medion Database, but we can read! 😉
But you seemingly not 🙂
Your choice of words is absolutely inappropriate and impertinent. Stop insulting other users in this way.
@bublik schrieb:
Did last try at a local Chinese store and of course they had the proper plug which is 5.5*2.5, could be useful to someone else in the future looking at this thread
That is correct. Thank you for the information.
This was an error in our database. This has already been corrected. Thank you very much for the hint.
Greetings - Andi
