medion akoya e7225 won't start
2 ANTWOORDEN 2
omarbhd
Bericht 1 van 3
1.739 Weergaven
Bericht 1 van 3
1.739 Weergaven
Hello, I have a medion akoya e7225 that have no signs of life apart from small clics when i plug the charger in,
please help!
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
omarbhd
Bericht 3 van 3
1.664 Weergaven
Bericht 3 van 3
1.664 Weergaven
Hi @Gehringer thank you very much for your reply but i just found the problem,it was a ram issue.
2 ANTWOORDEN 2
Gehringer
Retired
Bericht 2 van 3
1.737 Weergaven
Bericht 2 van 3
1.737 Weergaven
Hi @omarbhd and welcome to the FORUM!
Does the led charging light switch on?
If it does not, can you try with a different charger?
If none of the troubleshooting works, I believe you will need to contact your local Medion technical support team
Regards,
Gehringer
omarbhd
Bericht 3 van 3
1.665 Weergaven
Bericht 3 van 3
1.665 Weergaven
2 ANTWOORDEN 2
