max RAM of the MEDION laptop MD97600 WIM 2090
2 REPLIES 2
cons
Message 1 of 3
Message 1 of 3
Dear Medion team,
What is the max RAM of my laptop Medion MD97600 WIM 2090 (from 2006)?
It is said 2GB at https://www.amazon.de/-/en/Medion-MD97600-Laptop-Memory-Upgrade/dp/B002Z5P5ZI
Is this correct? Can it handle 2GB of RAM? I am planning to upgrade the RAM
Thanks & looking forward to hearing from you ASAP
2 REPLIES 2
elfo
Message 2 of 3
Message 2 of 3
Hiya
Have you tried running a Scan on your laptop from Crucial Memory?   That will analyse the laptop, and give you some info about what the max RAM is.
Crucial System Scanner | Memory Upgrade Scanner | Crucial
Mastermind
Message 3 of 3
Message 3 of 3
Hi @cons  & @cons and first of all sorry for the late reply,
this one seemed to have slipped, but apart from the original config, which was 1x 512 MB Hynix DDR2 S0-DIMM (533MHz), the MEDION MD 97600 is able to take summarised 2 GB RAM (1 Gb each per slot) max.
If further questions occur,pls letme know.
Cheers
2 REPLIES 2
