VGA / HDMI adaptor for Akoya S4403
2 ANTWORTEN 2
JimH
Nachricht 1 von 3
1.508 Aufrufe
Nachricht 1 von 3
1.508 Aufrufe
Hi,
I'm trying to use the USB-C displayport with a multiport adaptor to connect the laptop to either a VGA monitor or an HDMI television with no success.
Does anyone know of an adaptor that is definitely compatible for both HDMI and VGA for this laptop?
thanks, Jim
2 ANTWORTEN 2
Nachricht 2 von 3
1.506 Aufrufe
Nachricht 2 von 3
1.506 Aufrufe
@JimH
As you say , it is a display-port. So you need an adaptor  USB-C to Display-Port. That's all.
If behind this you can add other adptors to convert to HDM or VGA, I do not know.
But first you have to extract the display-port signal from the C-port.
JimH
Nachricht 3 von 3
1.502 Aufrufe
Nachricht 3 von 3
1.502 Aufrufe
Thanks @daddle.
There are loads of adaptors available that go straight from the "USB C Displayport" to female HDMI and/or VGA, but compatibility varies.  Just trying to find out if anyone connects this model laptop to a monitor or projector and which adaptor they use.  I can't be the first person to do this.
Regards, Jim
2 ANTWORTEN 2
