Replace Medion Akoya E14409 (MD62157) SSD
8 REPLIES 8
hayolie
Message 1 of 9
Message 1 of 9
Hello, I have a Medion Akoya E14409 (MD62157) laptop and I would like to upgrade the SSD drive to something with more storage. According to Windows device manager the current 128GB SSD is a "Neo Forza NSN095SA328-Y01Q1I0".
Can I replace it with any M.2 / SATA SSD? M.2 2280 for example? What's the maximum storage and are there any physical requirements to take into account?
Thank you!
1 ACCEPTED SOLUTION
Mastermind
Message 5 of 9
Message 5 of 9
Hi @hayolie ,
we officuially tested your AKOYA E14409 laptop  up to a SSD capacity of  max 256 GB (M.2 2280 SATA connct), but of course you also could try a bigge module in a PC/laptop workshop of yours to figure out 512 GB module
You will find the currend SSD module left to the housing fan like seen in this picture below.
Hope that helps
8 REPLIES 8
RAZZ
Message 2 of 9
Message 2 of 9
Dear @hayolie
please can you confirm the MS of this unit so we can fully identify and try and assist, as MD62157 was sold in several different countries with different specs.
thanks
hayolie
Message 3 of 9
Message 3 of 9
Hi @RAZZ. Thanks for the reply.
On the back it has the following numbers:
MD 62157add2
MSN 30033146
It was bought in the Netherlands. Hope that helps!
RAZZ
Message 4 of 9
Message 4 of 9
dear @hayolie
I apologise but I am still not able to identify the exact unit maybe the Dutch community can help
https://community.medion.com/t5/Nederlands/ct-p/NL
thanks
Mastermind
Message 5 of 9
Message 5 of 9
Hi @hayolie ,
Hope that helps
hayolie
Message 6 of 9
Message 6 of 9
Thank you so much @Major_ToM for the information and thank you @RAZZ for trying to help. I really appreciate it! 💜
Betoedo
Message 7 of 9
Message 7 of 9
Hello, i have the same model from the question above, but i just can't open the case at one side.
The part that gets stuck is the bottom closest to the screen hinges.
Do you have a video showing how you opened it? So I could copy the same way?
Thanks in advance
Message 8 of 9
Message 8 of 9
Hello @Betoedo and welcome.
You also have screws under the rubber feet.
bye Fishtown
Betoedo
Message 9 of 9
Message 9 of 9
Much appreciated!
I suspected as much, because it just wouldn't budge.
Thanks again
8 REPLIES 8
