P6815 Article No.30015318 display cable
3 RÉPONSES 3
rayishappy
Message 1 sur 4
1 712 Visites
Message 1 sur 4
1 712 Visites
Hi
I'm trying to find a replacement cable for the display. Is it listed here https://www.medion.com/medionserviceshop/search?sbf=true&sfs=1&msn=30015318 ? If so, which one is it? If not where can I get a suitable replacement cable?
Many thanks!
Ray
3 RÉPONSES 3
Raymond
Scientist
Message 2 sur 4
1 706 Visites
Message 2 sur 4
1 706 Visites
Hallo @rayishappy
look here
This notebook is from 2013 because you have no chance to maybe look at eBay
Gruß Raymond
rayishappy
Message 3 sur 4
1 696 Visites
Message 3 sur 4
1 696 Visites
Hello @Raymond
Thank you for your reply.
Is any of the 2 internal cables listed on https://www.medion.com/medionserviceshop/search?sbf=true&sfs=1&msn=30015318 (MSN: 40041206 and MSN: 40041209) the cable I need?
If not, when I search on Ebay, do you know if any other laptops use the same cable as my P6518?
Many thanks!
rayishappy
Message 4 sur 4
1 660 Visites
Message 4 sur 4
1 660 Visites
Anyone know which cable is for the display?
3 RÉPONSES 3
