Original BIOS Akoya P6687 - MD61006
30 REPLIES 30
kuro2
Message 1 of 31
Message 1 of 31
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
30 REPLIES 30
javigom
Message 11 of 31
Message 11 of 31
I'm going to tell what happened. As you know, version 207 of the bios is incompatible with Linux and that is why I got version 209, but when I installed it, the computer stops detecting the audio devices and the graphics card (which in my case is an MX150). I've tried installing both clean Linux and Windows and they don't work.
heywire2
Message 12 of 31
Message 12 of 31
javigom
Message 13 of 31
Message 13 of 31
I've tried tried to communicate in many ways with them but they do not give me a solution, if you could upload the bios I would appreciate it
heywire2
Message 14 of 31
Message 14 of 31
Sure, here you are: https://we.tl/t-MlqfufhgZu
javigom
Message 15 of 31
Message 15 of 31
Hi,
When I try to install it, it appears a message saying: "This BIOS is not for your Notebook PC." What should I do?
javigom
Message 16 of 31
Message 16 of 31
Does anyone know how to fix it? My MSN is 30024225
Message 17 of 31
Message 17 of 31
@javigom
You arte sure you have the same version Windows installed as at the time the Biosfile  was published?
Your battery is at least 50% charged, and power supply is attached? Start the update with rightclick as an admin.
Regards, daddle
javigom
Message 18 of 31
Message 18 of 31
@daddle
No, I have the last update of Windows (20H2). What version of windows should I have?
Greetings
Message 19 of 31
Message 19 of 31
@javigom
This I do not know exactly.  It depends on which date you bought your PC, and the date of when the Bios was published.
Similar PCs with the naming P6687 were sold wit Win 10; so I think your Win 10 is oK.
I just gave you some general rules.
javigom
Message 20 of 31
Message 20 of 31
@daddle
So there is no solution? Medion technical service does not respond to me ...
30 REPLIES 30
