on 17.07.2018 12:33
on 17.07.2018 12:33
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
on 19.07.2018 09:57
on 19.07.2018 09:57
Hi Kuro2.
I have called to the technical service because I upgrade the BIOS in the same computer model as you and the sound stop working... They told me that only have the BIOS software that you can find here:
I am interested in the original BIOS software to recover back the sound, as Kuro2. Can anybody help us?
Thank you very much.
on 19.01.2019 01:07
on 19.01.2019 01:07
I talked to the Spanish Medion team but nobody could give me any solution.
I wanted to update my bios so that I could enter in my linux distros (which 203 bios version seems to have blocked), and so I did.
I first experienced that sound wasn't working at all in windows and the laptop was overheating, but I magically could enter in my linux distros. I've tried everything with version 203 but nothing worked. I could return it to Amazon and take a new one, but I'm unable to enter my linux distros again.
I wish Medion would help us providing a correct bios version, because the listed one, which says 2.07, is indeed 2.09 and is not working fine. Please provide a valid bios update so that we can use our devices freely.
on 08.01.2021 08:51
on 08.01.2021 08:51
Could you send me 2.09 bios? I can not find it anywhere. It has a problem with csm but I am not using it.
Thanks.
on 17.02.2021 07:00
on 17.02.2021 07:00
Hi @amon-ra , @kuro2 , @LBA997 , @VictorD
sorry for the late reply, but I cann offer you the version 2.08, which might help as a WINFlash Update.
Greets
on 17.02.2021 09:42
on 17.02.2021 09:42
Hi, I can't download the bios from the page, what should i do?
on 17.02.2021 14:00
on 17.02.2021 14:00
HI @javigom ,
it really depends on which specific machine you´re operating and which current Bios is installed on it.Could you please come around with a littlemore information?
Cheers
on 17.02.2021 17:30
on 17.02.2021 17:30
Hi,
Mi model is P6687 and my bios version is v209, but the audio and nvidia drivers doesn't work.
Thanks.
on 17.02.2021 18:07
on 17.02.2021 18:07
Flashing 208 will fix the issue, do you need an alternative link?
on 17.02.2021 18:39
on 17.02.2021 18:39
Yes! The link post here (https://community.medion.com/t5/FAQs/BIOS-updates-concerning-the-Meltdown-Spectre-vulnerability-for/...) doesn't work. But I think that the version for the P6687 model is 207, not 208.
