Medion s4401 i3-7020U/8 charger characteristics
1 REPLY 1
Viktorija
Message 1 of 2
Message 1 of 2
I want to ask where I can find an information about Medion s4401 i3-7020U/8 charger characteristics and the tip size of it?
1 REPLY 1
Message 2 of 2
Message 2 of 2
Hi @Viktorija and welcome
Everything is written on the back of the power supply:
FSP065-REB C6 3pin 65W/ 3.42A / MSN No.40068634
https://www.medion.com/medionserviceshop/search?sbf=true&sfs=0&msn=40068634
Please check if this plug size is the same and also pay attention to that if you order from an online shop whether this has the same size, some with other plugs are offered.
DC Plug inside: 3,5 mm plug/ outside: 5,5 mm plug
bye Fishtown
1 REPLY 1
