Medion P6645 KeyBoard is completely worn out and how do I open it to upgrade memory?
2 REPLIES 2
HedgePig
Message 1 of 3
Message 1 of 3
My partner has had a Model P6645 for about a year now, the keyboard is pretty much illegible from use, which isn't great but maybe if someone can confirm if this is normal? She now stands a replacement external keyboard OVER the original one so it can be used. Not ideal.
And then I would like to upgrade the memory, can this be done, what DIMMs (if those?) do I need to order and how do I open the laptop up, do I need any tools?
Thanks! HP.Badly worn keys...Badly worn keys...
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Hi @HedgePig and welcome
Please state the MSN number.
the comparable notebooks P6645 have a RAM of two options:
Onboard none Slots 1x 8192 MB DDR4 SO-DIMM (PC4-19200/2400MHz) 1/2 covered Max. Capacity (chipset support) 16GB
most have the device screwed and clipped with plastic lugs.
is your keyboard still working? use key stickers!
https://www.amazon.de/Aufkleber-Buchstaben-Standard-Tastatur-Laptop-Tastatur-Apple-Tastatur/dp/B08RZ...
bye Fishtown
Message 3 of 3
Message 3 of 3
@HedgePig  @Fishtown
The listing is misleading, in the Database a semicolon s missing. It should say
" Onboard none;  Slots 1x 8192 MB DDR4 SO-DIMM (PC4-19200/2400MHz) 1/2 covered Max. Capacity (chipset support) 16GB
So you can add another 8 GB in the second empty slot.
Her in this post you get som information how to open the case:
-> https://community.medion.com/t5/Notebook-Netbook/opening-up-a-p6645/m-p/93429/highlight/true#M463
Cheers, daddle
2 REPLIES 2
