Medion Erazer not tun on
3 ANTWOORDEN 3
Dachko_666
Bericht 1 van 4
2.287 Weergaven
Bericht 1 van 4
2.287 Weergaven
Hello i have Medion erazer that was working perfect in one moment and in another just turned of and for some reason the laptop was really hot  . Now the laptop doesn’t want to turn on again when I try the touchpad it’s flashing but the laptop is not turning on. The battery is integrated so I can’t take it out  the msn is - 30022237
3 ANTWOORDEN 3
Gehringer
Retired
Bericht 2 van 4
2.282 Weergaven
Bericht 2 van 4
2.282 Weergaven
Hi @Dachko_666 ,
I believe your unit will need to be assessed by a technician.
I would advise you to get in touch with your local Medion technical support team.
Is your unit still in warranty?
If so, then the repair is likely to be performed free of charges.
Regards,
Gehringer
Dachko_666
Bericht 3 van 4
2.279 Weergaven
Bericht 3 van 4
2.279 Weergaven
Unfortunately the warranty ends on 01-01-2021 so I will need to pay the repair ... I hope that is not the motherboard
Bericht 4 van 4
2.272 Weergaven
Bericht 4 van 4
2.272 Weergaven
Hi @Dachko_666
report the damage now 31.12.2020 you still have a guarantee.
bye Fishtown
3 ANTWOORDEN 3
