Medion Erazer X7827 does not access BIOS
2 ANTWOORDEN 2
Laki
Bericht 1 van 3
2.124 Weergaven
Bericht 1 van 3
2.124 Weergaven
Hello,
The notebook of my friend fail to start just a few days ago. On the screen it had this:
 In that stage i created a Windows 10 installation USB stick from Microsoft web site and try access bios to change boot priority. The keys ESC, F2, F8, F9, F10, F11, F12, Delete does not work...  Also i found, i can't eject a DVD Rom tray, it just clicking...
I open back cover, there is SSD 240 G, just fitted on SATA slot but not secured in place. I swap a ssd fron my desktop to this Medion just to try can i go to bios, but all still the same. Then i put back the original ssd. Today on start i got a different screen:
 I'm lost... For me it looks like a hardware problem. Can some body give me a advise what to do in that stage.
Sorry for my bad english.
Regards, Andrew
2 ANTWOORDEN 2
Bericht 2 van 3
2.113 Weergaven
Bericht 2 van 3
2.113 Weergaven
@Laki
Hi Laki.
All your errors  say your primary adressed booting medium (a sdcard, a DVD disk, USB Stick or the SSD) is faulty or missing,
1.  Is there a SDcard left in the cardreader?
2.  Is there an DVD in the CD/DVD tray? How come you can not open it? Normally it opens with a short pressure on the tray or the button on it. There is only in the beginning a moment during post and the start up of the PC, when you can not open it. And usually ther is a little hole in the tray. to open it mechanically with a bent open paper clip.
3.  If you opend the bottom, it is easy to remove the DVD drive. You have to find the one screw, which holds the drive.
4.  Just estimate the square size of the drive, unscrew the screw which you should see at the estimated back of the drive housing, and you can pull it out like a sledge.
5.  When the first error came up? After a Windows Update/Upgrade?
6.  So but why doesn't it boot from the USB Stick? Did you create it with the MediaCreationTool from the Microsoft webpage?
7.  If not, make use of this.  (MediaCreationTool20H2.exe)
8.  You have choose the 64 GB Version of Windows, and your USB Stick has to be min 8 GB.
9.  Did you press the F10 or F8 immediately at start of the PC? Some PCs needs the  F10 key, other the F8 key to start up with the Boot menu on the screen. Ther you can choose te USB Stick
10 You did choose the 64 GB Version of Windows, and your USB Stick has to be min 8 GB.
The second screen only says the NB tried to boot from a network device. Which you can  neglect. But it tells us that the Bios didn't find a bootable media.
Did you press the F2 key before starting the PC? The F2 Key is the key for entering the UEFI Bios.
Here is the download for the english manual.  Are you from Denmark, or which country are you from?
Awaiting your answers,
Laki
Bericht 3 van 3
2.090 Weergaven
Bericht 3 van 3
2.090 Weergaven
Hi Daddle,
Thank you so much for so comprehensive answer.
I have done all that steps. There is no SDcard left in the card reader. The DVD I removed and checked inside, there is no disc...
This error just occurs. My friend said there was no windows update recently.
The problem is I can't go to the Boot menu. The keys F8, F10, ESC, Delete, F2 and other does not work.
Also, I can't go in the UEFI Bios with the F2 key before starting the PC.
I think it is BIOS software problem or some hardware issue...
I will give this laptop back to my friend, this job probably for a specialized service
I'm Ukrainian, living in Ireland
Thank you again,
Kind regards,
Andrew
2 ANTWOORDEN 2
