on 12.04.2024 21:59
on 12.04.2024 21:59
Hi there,
for a: Medion Erazer Deputy P60 MD 62591 (UK)
MSN 3003 6528
Was hoping for some clarification please, do the USB-C ports support DP alt mode?
Planning to use a dock to connect a monitor and other peripherals.
Any clarification is muchly appreciated,
Cheers
on 13.04.2024 15:59
on 13.04.2024 15:59
Ended up phoning product support, they confirmed the USB-C port supports DP Alt-mode. (Take it with a pinch of salt though as agent did not sound too sure).
Thanks 🙂
13.04.2024 19:06 - edited 13.04.2024 21:31
@dooties schrieb:Ended up phoning product support, they confirmed the USB-C port supports DP Alt-mode. (Take it with a pinch of salt though as agent did not sound too sure).
He should have declared which USB port. On the left or right side of the laptop?
I do not think so. The NB has a dedicated Mini Display Port und the right side ( siehe picture in the manual) next to a USB Port 3.2, Gen 2 (type C) .
So why should the USB C-port supports an DP alt. mode?
But who knows, look in the specs of the mb at Clevo.
--> https://www.medion.com/de/service/product-detail/30036528
