op 05.01.2021 00:49
op 05.01.2021 00:49
Hi there,
I'm considering purchasing the Medion Crawler E10 but I wanted to find out first what the fans are like on idle or normal usage. My current laptop constantly ramps up and down, even on idle use, and I'm unable to manually set the fan curve. With the Control Centre for the E10, is there an option for custom fan curve or are there the usual presets (quiet, turbo etc) only?
Thank you
op 07.01.2021 04:02
op 07.01.2021 04:02
Hi,
I just got my brand new Crawler E10 today and can confirm the fan relentlessly stops and starts under every day load such as scrolling Chrome.
Whilst this laptop does come with a 'custom' option for plotting your own curve, the CPU fan is locked to a 45 degree trigger point which cannot be modified at all (up or down); rendering this feature useless at remedying the nuisance. Honestly, I really would rather the fan always be on - it's not even loud at lower temps. Super super frustrating having it stop and start every 30 seconds, and no doubt will lead to more wear and tear on the hardware.
I hope this helps.
10.03.2021 07:22 - bewerkt 11.03.2021 05:49
op 01.04.2021 11:32
op 01.04.2021 11:32
The battery isn't enormous and that shouldn't be an issue except if your sole center is the battery life also.
