le 13.02.2024 17:26
le 13.02.2024 18:25
le 13.02.2024 18:25
Hi @Library3088 and welcome
try here:
https://www.touchandscreen.de/LED-Display-156-1366x768-matt-passend-fuer-Medion-Akoya-S5612
bye Fishtown
le 13.02.2024 20:17
le 13.02.2024 20:17
Thankyou
I asked for a manual because I've made a bit of a mess trying to find a part number.
The circuit board on the link you sent doesn't look like mine and neither do any others i've seen available to buy.
le 13.02.2024 20:17
le 13.02.2024 21:33
le 13.02.2024 21:33
Hi @Library3088
Circuit board? I felt like I read something about a broken screen that needed to be replaced:
@Library3088 schrieb:The screen is cracked and I need to replace it.
Bye Fishtown
le 13.02.2024 21:52
le 13.02.2024 21:52
I mean the board on the back of the screen. This is a picture of the back of my cracked screen. It is different to the one in the link you posted. The board is shorter than mine and the cable that attaches on the left hand side is in a different position and orientation.
le 13.02.2024 21:58
le 13.02.2024 21:58
Actually, sorry, I've just realised that the left hand cable is part of the unit itself.
