Medion Akoya E14410
20 ANTWOORDEN 20
deyu23
Bericht 1 van 21
10.435 Weergaven
Bericht 1 van 21
10.435 Weergaven
Medion Akoya E14410
I want to upgrade ssd (i just have 128gb) and ram memory.
Just checked with a few programs (CPU Z) and show the laptop have 2 slots for ram, one slots are occupated with 4gb and one free.
I want to know, what type of ssd are compatible and where are the ram (both slots located
Thnak you
20 ANTWOORDEN 20
deyu23
Bericht 11 van 21
4.522 Weergaven
Bericht 11 van 21
4.522 Weergaven
Just 256 GB its the maxim supported ? Why just that 😞
Bericht 12 van 21
4.521 Weergaven
Bericht 12 van 21
4.521 Weergaven
@Andi
Hallo Andi, HappyNew Year.
Danke für die Bestätigung meiner Angaben in Post 2. Mir glaubte @deyu23 wohl nicht.
@daddle   schrieb:
 @deyu23
Sorry, but your E14410  only has one ram slot; equipped with 4 GB. Maximum the database says is 32 GB.
-->   1x 4096 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz) (1/1 covered; 32 GB max.)
Wichtig ist die Ergänzung der Begrenzung auf 256 GB für die SSD. Aber ist  es vielleicht so, wie bei manchen anderen Modellen auch, dass nur die 256 GB getestet sind, aber über Try und Error zeigen könnte, dass auch eine 500 GB M2  funktioniert?
Bericht 13 van 21
4.508 Weergaven
Bericht 13 van 21
4.508 Weergaven
Hi @deyu23
the probability is high that you have 512GB can naue. you have a:
MEDION AKOYA E14410 (MD 63800)
BB JP E14410 SF40IL6 MD gr/bk w LTE
the sister model is almost identical and has the same board and cpu but SSD M.2 512GB SATA
MEDION AKOYA E14409 (MD 62331)
BB JP E14409 SF40IL6 MD gr/bk w/o LTE
  • SSD (M.2) (2280) Sata; 512 GB
order the 512GB, what happens in the worst case? you have to exchange them 😎
bye Fishtown
kommodore_ss
Bericht 14 van 21
4.478 Weergaven
Bericht 14 van 21
4.478 Weergaven
Guys , how you managed to open the back case? i struggle a lot and can't open the part near the screen
deyu23
Bericht 15 van 21
4.466 Weergaven
Bericht 15 van 21
4.466 Weergaven
You also have screws on the legs of the laptop, peel them slowly with something sharp, then you can put them back without any worries
deyu23
Bericht 16 van 21
4.466 Weergaven
Bericht 16 van 21
4.466 Weergaven
kommodore_ss
Bericht 17 van 21
4.457 Weergaven
Bericht 17 van 21
4.457 Weergaven
Thank you, sadly the fan was very noisy and while trying to fix it , i completly broke the fan...any chance i can find a spare one?
Thank you!
Tags (1)
deyu23
Bericht 18 van 21
4.447 Weergaven
Bericht 18 van 21
4.447 Weergaven
That's right, you're right, the fan is very noisy and extremely small, at first I thought the laptop had a problem.
Unfortunately, I don't know you where to try to find a suitable fan.
kommodore_ss
Bericht 19 van 21
4.443 Weergaven
Bericht 19 van 21
4.443 Weergaven
Guess we need to search for a replacement... can you handle the noise?
deyu23
Bericht 20 van 21
4.438 Weergaven
Bericht 20 van 21
4.438 Weergaven
I got used to accepting the noise of fan.  But I can't adapt with the sound quality of the speakers. Nokia n95 sound better :)))
20 ANTWOORDEN 20
