Medion Akoya E14410
20 RÉPONSES 20
deyu23
Message 1 sur 21
10 362 Visites
Message 1 sur 21
10 362 Visites
Medion Akoya E14410
I want to upgrade ssd (i just have 128gb) and ram memory.
Just checked with a few programs (CPU Z) and show the laptop have 2 slots for ram, one slots are occupated with 4gb and one free.
I want to know, what type of ssd are compatible and where are the ram (both slots located
Thnak you
1 SOLUTION APPROUVÉE
Solutions acceptées
Message 10 sur 21
4 748 Visites
Message 10 sur 21
4 748 Visites
Hello @daddle.
I have once inquired with our technical department regarding the technical data. I received the information that the device has only one RAM slot. However, this can be equipped with up to 32 GB. The SSD is not a 2.5" variant, but an M.2 SSD. Only SATA M.2 SSDs with up to 256 GB are supported. The information in our database will be corrected.
Greetings - Andi
20 RÉPONSES 20
Message 2 sur 21
4 817 Visites
Message 2 sur 21
4 817 Visites
@deyu23
Sorry, but your E14410  only has one ram slot; equipped with 4 GB. Maximum the database says is 32 GB.
-->   1x 4096 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz) (1/1 covered; 32 GB max.)
It's a bit funny, ussually the slots in those smaller NBs only have a capacity of 16 GB max. May be there is a print error.
Your SSD is a 128 GB with SATA III (6 GB/s) interface. This you can replace with any SSD in 2.5" format.  At least it should manage a 512 GB SSD. Check  the thicknes before buying a new one. But with 7 mm it is oK.
Cheers, daddle
deyu23
Message 3 sur 21
4 814 Visites
Message 3 sur 21
4 814 Visites
this is the ssd ?
Message 4 sur 21
4 809 Visites
Message 4 sur 21
4 809 Visites
@deyu23
It takes some time before a mod has given approval to your picture and it can be seen by other users.  If it contains the serial numer as well, it will not be approved.
So just post the MSN  of your PC here.
deyu23
Message 5 sur 21
4 808 Visites
Message 5 sur 21
4 808 Visites
I open the laptop, and post picture with ssd, just to confirm or infirm thats the ssd.
MSN 30031494
Message 6 sur 21
4 802 Visites
Message 6 sur 21
4 802 Visites
@deyu23
You don't have to open the laptop.
The disk management tells which disk is installed. In the database it is listed as a 128 GB SSD.
And with msinfo32 , HW-info or CPU-Z it should tell the number of slots.
deyu23
Message 7 sur 21
4 800 Visites
Message 7 sur 21
4 800 Visites
https://imgur.com/a/58AM6AF   i think this is NVMe SSD , what do you think ?
Message 8 sur 21
4 794 Visites
Message 8 sur 21
4 794 Visites
@deyu23
It's definitely not a 2,5" Notebook SSD, but a M.2 SSD. There must be a wrong database entry. Which protocol I can't tell just by the looks of it.
Maybe the RAM entry is not correct  as well.
Edit:
But checkíng the backside of the socket with the contact wires seen, it is a good assumption to think it is a B-Key socket, which means most probably the mounted M.2 SSD is a SATA M.2.
Funny is, in your picture the mounting place looks like  a cradle for a 2.5" Notebook disk; but  equipped with an adapter for M.2 SSDs; so only M.2 SSDs (SATA) will fit.
@Andi , could you please be so kind to check this matter, and correct the given information concerning the SSD?
Thanks in advance.
Regards, daddle
deyu23
Message 9 sur 21
4 783 Visites
Message 9 sur 21
4 783 Visites
With CPU-Z and msinfo32, show me 2 slots for memory ram, 1 occupied with 4gb ram. When i open the laptop, i cannot find the second slot !
Message 10 sur 21
4 749 Visites
Message 10 sur 21
4 749 Visites
Hello @daddle.
Greetings - Andi
20 RÉPONSES 20
