on 02.04.2021 07:39
on 02.04.2021 07:39
Hi there, I'm having trouble with my inbuilt mic not working at all. I first noticed when using Zoom but when I go into settings and Test Microphone it doesn't register anything. I've tried a factory reset but still get no response - even when I select Realtek or System. Has anyone any ideas what I could try?
Many thanks
on 02.04.2021 08:28
on 02.04.2021 08:28
Hi @dr_hfuh
Switch not turned on, on the side?
see page No.15: “Private mode” sliderswitches the webcam and internal microphone on/off
or Aldi User manual Page 6 / No.14
bye Fishtown
on 02.04.2021 08:42
on 02.04.2021 09:29
on 02.04.2021 09:29
Hi @dr_hfuh
was there a Windows update two weeks ago?
Look in the device manager, is there an exclamation point somewhere?
Try the Medion service app:
https://community.medion.com/t5/FAQs/FAQs-zur-MEDION-Service-App/ta-p/83509
http://medion.servify.tech/MedionServiceApp.msi
bye Fishtown
Useful driver package:
www1.medion.de/downloads/index.pl?op=detail&id=20192&type=treiber&lang=uk
on 02.04.2021 11:00
on 02.04.2021 11:00
Hi @Fishtown, I think there was an update about 2-3 weeks ago. I've looked in Device Manager and there's no exclamation marks or any indication that there's anything wrong with the mic. I ran diagnosis on the Medion Service app and again it said all was fine. I've installed that driver package and it was succesfull with 7 out of 12. I'll paste the log on the end of this message. I restarted but still nothing from the inbuilt mic. Thanks again for your help - the mic on my headphones works fine if that's of any relevance?
CHECKING IF DRIVERS ARE PRESENT:
01.AMD_Chipset\*.inf exists.
02.AMD_Audio\*.inf exists.
03.AMD_VGA\*.inf exists.
04.AMD_PSP\*.inf exists.
06.Codec_8843\*.inf exists.
07.WLAN_21_40\*.inf exists.
08.BT_21_40\CCP\*.inf exists.
08.BT_21_40\HRP\*.inf exists.
08.BT_21_40\JFP\*.inf exists.
08.BT_21_40\SDP\*.inf exists.
08.BT_21_40\SFP\*.inf exists.
08.BT_21_40\STP\*.inf exists.
08.BT_21_40\THP\*.inf exists.
08.BT_21_40\WSP\*.inf exists.
09.CardReader\*.inf exists.
INSTALLING DRIVERS:
PNPUtil -a "01.AMD_Chipset\*.inf" /Install
Microsoft PnP Utility
Processing inf : AmdAS4.inf
Successfully installed the driver.
Driver package added successfully.
Published name : oem26.inf
Processing inf : AmdGpio.inf
Published name : oem4.inf
Processing inf : amdgpio2.inf
Failed to install the driver : No more data is available.
Processing inf : amdhdc.inf
Published name : oem12.inf
Processing inf : amdi2c.inf
Processing inf : amdsfhkmdf.inf
Published name : oem38.inf
Processing inf : amdsfhkmdfi2c.inf
Processing inf : amdsfhspbi2c.inf
Published name : oem9.inf
Processing inf : amdsfhumdf.inf
Published name : oem19.inf
Processing inf : amduart.inf
Published name : oem16.inf
Processing inf : SMBUSamd.inf
Processing inf : usbfilter.inf
Total attempted: 12
Number successfully imported: 7
Installation failed! (ErrorLevel: 259)
Press 'C' to continue or just Enter to exit:
on 02.04.2021 11:48
on 02.04.2021 11:48
Hi @dr_hfuh
Is the microphone activated under sound / settings / input device and entered as standard?
Try Settings / System / Sound / Troubleshooting
Do you still have Windows 10 S mode on or changed?
bye Fishtown
on 02.04.2021 12:43
on 02.04.2021 13:05
on 02.04.2021 13:05
Hi @dr_hfuh
Control Panel / Hardware and Sound / Recording
look to see if the microphone is entered as the default device under recording devices.
bye Fishtown
on 02.04.2021 13:44
