Laptop has difficulty connecting to internet
2 REPLIES 2
MattA1
Message 1 of 3
Message 1 of 3
Hi,
Most times when I turn my laptop on it doesn't recognise or can't connect to my internet - I get a message saying that WiFi doesn't have a valid IP configuration. I can get round this problem by releasing and then renewing the IP configuration, but I have to do this each time I want to use the internet.
Is there a more permanent solution?
Thanks so much for any help!
Matt
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @MattA1 ,
I would advise you to update your Windows and network adapter drivers to the latest version.
Then, I would advise you to switch off your notebook, switch off your internet router for about 5 minutes and then switch the router back on so it will update automatically.
Once the router finishes updating (around 10/15 mins), switch your notebook back  on.
Regards,
Gehringer
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @MattA1 ,
Regards,
Gehringer
MattA1
Message 3 of 3
Message 3 of 3
Thanks very much - this worked 😀
2 REPLIES 2
