Laptop has difficulty connecting to internet
2 ANTWOORDEN 2
MattA1
Bericht 1 van 3
2.877 Weergaven
Bericht 1 van 3
2.877 Weergaven
Hi,
Most times when I turn my laptop on it doesn't recognise or can't connect to my internet - I get a message saying that WiFi doesn't have a valid IP configuration. I can get round this problem by releasing and then renewing the IP configuration, but I have to do this each time I want to use the internet.
Is there a more permanent solution?
Thanks so much for any help!
Matt
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Gehringer
Retired
Bericht 2 van 3
2.869 Weergaven
Bericht 2 van 3
2.869 Weergaven
Hi @MattA1 ,
I would advise you to update your Windows and network adapter drivers to the latest version.
Then, I would advise you to switch off your notebook, switch off your internet router for about 5 minutes and then switch the router back on so it will update automatically.
Once the router finishes updating (around 10/15 mins), switch your notebook back  on.
Regards,
Gehringer
2 ANTWOORDEN 2
Gehringer
Retired
Bericht 2 van 3
2.870 Weergaven
Bericht 2 van 3
2.870 Weergaven
Hi @MattA1 ,
Regards,
Gehringer
MattA1
Bericht 3 van 3
2.845 Weergaven
Bericht 3 van 3
2.845 Weergaven
Thanks very much - this worked 😀
2 ANTWOORDEN 2
