LAPTOP MEDION AKOYA MD62034
10 ANTWOORDEN 10
JoseAlberto
Bericht 1 van 11
5.749 Weergaven
Bericht 1 van 11
5.749 Weergaven
I would like to know if it is possible to upgrade RAM from 16 Gb to 32 Gb for the model MD62034.
Kind regards.
2 GEACCEPTEERDE OPLOSSINGEN
Geaccepteerd Solutions
Bericht 3 van 11
5.029 Weergaven
Bericht 3 van 11
5.029 Weergaven
@JoseAlberto  @RAZZ
There is only one notebook  with this given  MD 62034 number.
So MSN should be MSN 3003 0326.
The specs for the memory  states the following:
  • Memory: 2x 8192 MB DDR4 SO-DIMM (PC4-25600 / 3200 MHz)(2/2 covered; 16 GB
 This is the maximum Medion tested
Sometimes some Notebooks  can  take more memory in size.  But this would be a trial from your side. And indeed I doubt it for this notebook, because it  means you would have to double the module size per slot.
Regards, daddle
Edit: Typo
Bericht 9 van 11
4.887 Weergaven
Bericht 9 van 11
4.887 Weergaven
@JoseAlberto
@JoseAlberto  schrieb
The identification is S15449-MD62034 MSN 30030326.
I had seen the official information but I thought that it was a bit strange that it was not possible to upgrade Ram to 32Gb.
Thats very nice from your side!  . Then you should have said so, and should have just asked for verifiication.
In this way you waste time of other users.
10 ANTWOORDEN 10
RAZZ
Bericht 2 van 11
5.047 Weergaven
Bericht 2 van 11
5.047 Weergaven
Hi @JoseAlberto
Please can you confirm the 8 digit MSN number? (found underneath the unit on a sticker)
With this I can correctly identify the model and check RAM specs
thanks
Bericht 3 van 11
5.030 Weergaven
Bericht 3 van 11
5.030 Weergaven
@JoseAlberto  @RAZZ
Regards, daddle
Edit: Typo
Bericht 4 van 11
5.014 Weergaven
Bericht 4 van 11
5.014 Weergaven
Hi @daddle
Here's another one:
https://www.medion.com/de/service/topic/medion-products?msnCheck=30033799
bye Fishtown
Bericht 5 van 11
5.008 Weergaven
Bericht 5 van 11
5.008 Weergaven
@Fishtown
Das hilft auch nicht wirklich weiter.
Der ist unter der dazu gelisteten MSN nicht einmal  im Intranet zu finden. Und auf der Serviceseite fehlen alle Specs. Unter der MD 62034 kam nur der eine, den ich benannte.  Gerade noch mal getestet, jetzt ist das auch noch so.
Kann man sehen wie genau die Datenbanken gepflegt werden.
Und was bedeutet SNB?
bye, daddle
Rex
Community Manager
Community Manager
Bericht 6 van 11
4.946 Weergaven
Bericht 6 van 11
4.946 Weergaven
Many thanks for the notes @daddle and @Fishtown .
There is indeed a variant of MEDION AKOYA S15449 (MD 62034) with the MSN 30033799.
We have now also added this to the database.
As a result, the specs can now also be found on our Service Homepage.
@daddle wrote:
(...) Und was bedeutet SNB? (...)
SNB is short for SlimNoteBook (i.e. a notebook with a low profile).
Rex
Bericht 7 van 11
4.938 Weergaven
Bericht 7 van 11
4.938 Weergaven
@Rex
Thanks for that.With the same MD-number 62034.  The specs are identical to them the other notebook with  MSN Nummer 30030326: shows. For Memory it's the same..
< 2x 8192 MB DDR4 SO-DIMM (PC4-25600 / 3200 MHz) (2/2 covered; 16 GB max.) >
@JoseAlberto
So my advise in Post 3 is still valid for all those SNBs (😉) with thre two known MSN numbers.
Cheers, daddle
Edit: Typo
JoseAlberto
Bericht 8 van 11
4.899 Weergaven
Bericht 8 van 11
4.899 Weergaven
Hi,
The identification is S15449-MD62034 MSN30030326.
Thanks to all.
Bericht 9 van 11
4.888 Weergaven
Bericht 9 van 11
4.888 Weergaven
@JoseAlberto
JoseAlberto
Bericht 10 van 11
4.836 Weergaven
Bericht 10 van 11
4.836 Weergaven
Sorry, i thought that the number that I had provided was the identificator.
Regards.
10 ANTWOORDEN 10
