LAPTOP MEDION AKOYA MD62034
10 REPLIES 10
JoseAlberto
Message 1 of 11
Message 1 of 11
I would like to know if it is possible to upgrade RAM from 16 Gb to 32 Gb for the model MD62034.
Kind regards.
2 ACCEPTED SOLUTIONS
Message 3 of 11
Message 3 of 11
@JoseAlberto  @RAZZ
There is only one notebook  with this given  MD 62034 number.
So MSN should be MSN 3003 0326.
The specs for the memory  states the following:
  • Memory: 2x 8192 MB DDR4 SO-DIMM (PC4-25600 / 3200 MHz)(2/2 covered; 16 GB
 This is the maximum Medion tested
Sometimes some Notebooks  can  take more memory in size.  But this would be a trial from your side. And indeed I doubt it for this notebook, because it  means you would have to double the module size per slot.
Regards, daddle
Edit: Typo
Message 9 of 11
Message 9 of 11
@JoseAlberto
@JoseAlberto  schrieb
The identification is S15449-MD62034 MSN 30030326.
I had seen the official information but I thought that it was a bit strange that it was not possible to upgrade Ram to 32Gb.
Thats very nice from your side!  . Then you should have said so, and should have just asked for verifiication.
In this way you waste time of other users.
10 REPLIES 10
RAZZ
Message 2 of 11
Message 2 of 11
Hi @JoseAlberto
Please can you confirm the 8 digit MSN number? (found underneath the unit on a sticker)
With this I can correctly identify the model and check RAM specs
thanks
Message 3 of 11
Message 3 of 11
@JoseAlberto  @RAZZ
Regards, daddle
Edit: Typo
Message 4 of 11
Message 4 of 11
Hi @daddle
Here's another one:
https://www.medion.com/de/service/topic/medion-products?msnCheck=30033799
bye Fishtown
Message 5 of 11
Message 5 of 11
@Fishtown
Das hilft auch nicht wirklich weiter.
Der ist unter der dazu gelisteten MSN nicht einmal  im Intranet zu finden. Und auf der Serviceseite fehlen alle Specs. Unter der MD 62034 kam nur der eine, den ich benannte.  Gerade noch mal getestet, jetzt ist das auch noch so.
Kann man sehen wie genau die Datenbanken gepflegt werden.
Und was bedeutet SNB?
bye, daddle
Rex
Community Manager
Community Manager
Message 6 of 11
Message 6 of 11
Many thanks for the notes @daddle and @Fishtown .
There is indeed a variant of MEDION AKOYA S15449 (MD 62034) with the MSN 30033799.
We have now also added this to the database.
As a result, the specs can now also be found on our Service Homepage.
@daddle wrote:
(...) Und was bedeutet SNB? (...)
SNB is short for SlimNoteBook (i.e. a notebook with a low profile).
Rex
Message 7 of 11
Message 7 of 11
@Rex
Thanks for that.With the same MD-number 62034.  The specs are identical to them the other notebook with  MSN Nummer 30030326: shows. For Memory it's the same..
< 2x 8192 MB DDR4 SO-DIMM (PC4-25600 / 3200 MHz) (2/2 covered; 16 GB max.) >
@JoseAlberto
So my advise in Post 3 is still valid for all those SNBs (😉) with thre two known MSN numbers.
Cheers, daddle
Edit: Typo
JoseAlberto
Message 8 of 11
Message 8 of 11
Hi,
The identification is S15449-MD62034 MSN30030326.
Thanks to all.
Message 9 of 11
Message 9 of 11
@JoseAlberto
JoseAlberto
Message 10 of 11
Message 10 of 11
Sorry, i thought that the number that I had provided was the identificator.
Regards.
10 REPLIES 10
