Is it possible to Upgrade/add more RAM to my MEDION ERAZER P6605 (MD 61586)
2 REPLIES 2
Jahrome
Visitor
Message 1 of 3
Message 1 of 3
Currently my gaming laptop has 8gb of RAM and I want to increase this to around 16GB, just wondering if and how i would do this
Tags (1)
2 ACCEPTED SOLUTIONS
Luke
Community Manager
Message 2 of 3
Message 2 of 3
Welcome @Jahrome ,
Upgrading your RAM is possible, according to the specs:
RAM:
1x 8 GB DDR4 SO-DIMM (PC4-21300 / 2666 MHz)
(1/2 Slots used; 32 GB max.)
Cheers,
Luke
mcketchup
Message 3 of 3
Message 3 of 3
all i think you need to do is open up the bottom, to just check which RAM is used (like ddr3 or 4), and just check what the max amount of RAM is on the motherboard and you are good to go
Hope this helps.
2 REPLIES 2
Luke
Community Manager
Message 2 of 3
Message 2 of 3
Welcome @Jahrome ,
RAM:
Cheers,
Luke
mcketchup
Message 3 of 3
Message 3 of 3
Hope this helps.
2 REPLIES 2
