I want to replace my hard drive with a Samsung 870 Evo, would it work?
2 REPLIES 2
brokentundra
Message 1 of 3
Message 1 of 3
My laptop is an Erazer P6679-MD60748. The SSD I want is a 2.5 inch SATA SSD so I'm just wondering if it would fit into the slot my laptop has. Thanks in advance. Here's the link to the SSD Amazon page:
https://www.amazon.co.uk/dp/B08PC43D78/ref=cm_sw_r_wa_apa_glt_fabc_Y0F79N84XVBYMXS5NB4R
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
@brokentundra
Yes the Samsung will fit.
But optionally you might have a second mounting place for a second disk, Check page 33 in the manual
--> https://bda.medion.com/bda_40062688.pdf
regards, daddle
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@brokentundra
regards, daddle
brokentundra
Message 3 of 3
Message 3 of 3
Thanks a lot, just wanted to make sure before I made a purchase
2 REPLIES 2
