HELP ME PLEASE! Trouble finding what charger to buy for MEDION AKOYA E15301 NOTEBOOK AMD RYZEN 7
4 REPLIES 4
sabrinamo
Message 1 of 5
Message 1 of 5
Hello,
My university recently gave me a Medion Akoya E15301 MD 62033 AMD Ryzen 7-3700U 8GB 512GB SSD and I have no clue what charger to use as I’ve lost the original charger. I tried to use a Usb C charger as there is a port for it and it manages to turn on but the power stays at 0. Please help me find a solution as i’m not very tech savvy. Thank you so much for any help you can give me!
4 REPLIES 4
Message 2 of 5
Message 2 of 5
Hello @sabrinamo and welcome
Is your MD number correct?
Power packs for your device are currently not in stock in the Medion spare parts shop. However, you can buy a charger for your USB-C port as it has a charging function (+DP).
But this should have at least 65 watts.
bye Fishtown
sabrinamo
Message 3 of 5
Message 3 of 5
Hello,
I hope you are well! Thank you so much for your response, however I had used a usb c charger to charge my laptop and it does not charge and consistently stays at 0. Is there anyway to fix this? Thank you again!
Message 4 of 5
Message 4 of 5
Hi @sabrinamo
The adapter must comply with the "USB Power Delivery" specification.
does yours have that?
bye Fishtown
sabrinamo
Message 5 of 5
Message 5 of 5
Hello thanks for the response.
There is a powder delivery symbol as well as a  lightning bolt next to the charging port so i’m not sure if this is any help?
4 REPLIES 4
