HDD/SDD 2.5" expansion on MEDION S6445
6 REPLIES 6
hashmiUNITED
Message 1 of 7
Message 1 of 7
Hi.
I wanted to know if it is possible to add and HDD/SDD 2.5" expansion on my  MEDION laptop.
I've seen YouTube videos which show an expansion slot on the bottom left corner of laptop when opened, but it seems I need a HDD caddy with connector to be able to add HDD.
Can you advise on which part I need to do this.
Please see video below:
https://www.youtube.com/watch?v=rYDOUALUxWs
Thanks.
Laptop details are:
MD 61322, MSN 30025962
6 REPLIES 6
Message 2 of 7
Message 2 of 7
@hashmiUNITED
Hi Hashmi,
the problem is as far as I know the caddy plus the connecting cable and plugs, which Medion doesn't supply.
Neither can you order them as spare parts.
EDIT: I tried this a couple of month ago. Although they were set on  "Available" , I couldn't place an order.
Sorry.
Cheers, daddle
hashmiUNITED
Message 3 of 7
Message 3 of 7
Thanks for answer.
Is there any third-party part that can be used for this laptop?
Message 4 of 7
Message 4 of 7
Hello @hashmiUNITED and welcome
are you willing to take risks?
there is a HDD cable from a S6445 with HDD
https://www.medion.com/medionserviceshop/search?sbf=true&sfs=0&msn=40069483
https://www.medion.com/medionserviceshop/search?msn=30026356
does it work with that? and is it the right one?  your risk!
Goodbye Fishtown
Message 5 of 7
Message 5 of 7
@hashmiUNITED
Nein das geht nicht. Wieso falsche Hoffnungen wecken?  Ich hatte die Frage nicht umsonst verneint.
Das hatte ich bereits hier abgeklärt. Das ist ein Kabel ohne Stecker.
Edit: War nicht bestellbar, trotz positiver Anfrage.
Message 6 of 7
Message 6 of 7
Hi @hashmiUNITED
found something else
https://www.ebay.de/itm/403620212099?var=0&mkevt=1&mkcid=1&mkrid=707-53477-19255-0&campid=5338765328...
bye Fishtown
hashmiUNITED
Message 7 of 7
Message 7 of 7
Thank you much appreciated.
6 REPLIES 6
