le 19.11.2019 09:48
le 19.11.2019 09:48
I use EaseUs ToDo backup system for all my PCs and laptops. To recover the whole system in the event of a crash I need to be able to boot from the CD/DVD drive.
How can I access Advanced set-up from a cold start on this particular model please? I can see how to access it if the laptop is running but that's not much use if the machine will not boot at all! The options provided after pressing F11 do not include 'Boot from CD/DVD'.
Hope someone can help on this?
le 24.11.2019 11:42
le 24.11.2019 12:51
le 24.11.2019 12:51
It doesn't boot, that is because it is not certified, if you did everything the right way making the CD, then it is so, that easus doesn't provide an UEFI compatible software.
But can't you start after disabling Secure Boot and enabling CSM Mode (or OS Win7 / Others or Legacy Mode ), than put the CD in Bios Boot in first place, or try to invoke the Bootmager by pressing FN + F10, FN + F8 may be FN + F12 after Start, and the cd shoul be shown.in the bootmanager.
le 24.11.2019 13:31
le 26.11.2019 12:41
le 26.11.2019 16:20
