le 09.11.2023 22:05
le 09.11.2023 22:05
Hi,
So after looking online etc. I've been unable to find the exact specification of the USB ports on this laptop, there's a lot of conflicting info.
Are the type A ports USB 3.0 or 3.1 and what's the difference there?
Is the Type C port USB 3.1 or 3.2? And what does it support? (Display Port, Power Delivery, Thunderbolt?) I was considering using a dock with a display out though I wasn't sure if it was supported.
What speeds etc. should I expect from the ports on this device?
Thanks,
- Biscuit
le 13.11.2023 16:59
le 13.11.2023 16:59
You can find the Manual here
--> https://www.medion.com/de/service/product-detail/30033537
Cheers, daddle
le 03.01.2024 08:16
le 03.01.2024 08:16
Hi @OrdinaryBiscuit and sorry for the late reply.
The USB port interface specifications of the Crawler E10 laptop are the following:
1 x USB 2.0 port Type A
2 x USB 3.2 Gen 1 port Type A
1 x USB 3.2 Gen 2 port TypeC
The Type-C port is just for data transport only and does not support DP or PD
Cheers
