Cooling fan running at max on start up
4 ANTWOORDEN 4
Mazakin
Bericht 1 van 5
2.545 Weergaven
Bericht 1 van 5
2.545 Weergaven
Madion akoya msn30020524. When i first acquired this laptop it ran great. But now the cooling fan is running at max at start-up and all the time i use it. Also since this has happened the laptop is not as quick as it used to be. I have just had a fresh windows installation to see if that would cure it, but has not helped.  As of now there is no programs running but fan still running at max.  Any suggestions much appreciated.
4 ANTWOORDEN 4
Gehringer
Retired
Bericht 2 van 5
2.512 Weergaven
Bericht 2 van 5
2.512 Weergaven
Hi @Mazakin,
you've mentioned you have already performed a clean Windows installation so I assume you've update Windows (including optional updates) and drivers to their latest versions, correct?
If so, you can try to install a monitoring software to check units' temperature to see it is a fan issue or an overheating issue.
It would also help to download and install the Medion Service app available here to look for faults.
Regards,
Gehringer
Mazakin
Bericht 3 van 5
2.487 Weergaven
Bericht 3 van 5
2.487 Weergaven
Hi, Thanks for your help, I ran the diagnostics as instructed. Did all updates and restarted, Got as far as checking video adapter and froze and would not go any further. Did this a second time and froze again on memory  test. So the fan is still running at max and programs  running slow. This laptop has not been used for awhile because of this problem.
   Quite awhile ago when this problem first started i was messing and i put the memory ram in the second empty slot and this cured the problem ?????. This ran perfectly  for about three months and then it started again and i have tried a new ram but still no good.  What you think?.
Gehringer
Retired
Bericht 4 van 5
2.468 Weergaven
Bericht 4 van 5
2.468 Weergaven
Hi @Mazakin ,
if your unit is in warranty I would advise you to call your local Medion technical support team and have it checked by a technician.
Regards,
Gehringer
Mazakin
Bericht 5 van 5
2.309 Weergaven
Bericht 5 van 5
2.309 Weergaven
Hi, We are still working on the unit. Fitted new ssd drive, Updates for nvidia which were missing, new rams, bios updates and do you know, it is still a pile of shit.
  Was hoping to play World of warcraft as a spare but it will not even load the game and if it do's it comes up 3d accelerator missing.
4 ANTWOORDEN 4
