BIOS password reset Akoya Laptop E4271
4 ANTWOORDEN 4
Akoya321
Bericht 1 van 5
1.233 Weergaven
Bericht 1 van 5
1.233 Weergaven
My Akoya Laptop E4271 is showing a Enter Password after booting (blue box with Enter Password). How do I reset my BIOS password on this system?
Thank you in advance.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Akoya321
Bericht 4 van 5
1.195 Weergaven
Bericht 4 van 5
1.195 Weergaven
I've figured it out by recalling the password.
4 ANTWOORDEN 4
Bericht 2 van 5
1.222 Weergaven
Bericht 2 van 5
1.222 Weergaven
@Akoya321
Hi Akoya321,,,
do you still know the Bios password, so you could enter Bios? Or are you asking because you have forgotten your PW?  If yes, you can not restore it. You can try to install Windows completely anew.
Dag, daddle
Akoya321
Bericht 3 van 5
1.204 Weergaven
Bericht 3 van 5
1.204 Weergaven
Thank you for answering so quickly.
I've forgotten the BIOS PW. Thought the BIOS PW was separate from the operating system. If I have time I'll check if there's a jumper on the mainboard for this model tot performance a BIOS reset tot Factory defaults. Another workaround worth trying is to drain the BIOS battery.
Akoya321
Bericht 4 van 5
1.196 Weergaven
Bericht 4 van 5
1.196 Weergaven
Bericht 5 van 5
1.191 Weergaven
Bericht 5 van 5
1.191 Weergaven
@Akoya321
I If I have time I'll check if there's a jumper on the mainboard for this model tot performance a BIOS reset tot Factory defaults. Another workaround worth trying is to drain the BIOS battery.
None of it would have worked.  But one has to save the Bios PW at a safe and easy to recall place. And not forget  the safe location. 😁
Bye, daddle
Edit: Typo
4 ANTWOORDEN 4
