le 09.01.2026 23:28
le 10.01.2026 23:19
le 10.01.2026 09:26
le 10.01.2026 18:37
le 10.01.2026 18:37
Thank you for answering so quickly.
I've forgotten the BIOS PW. Thought the BIOS PW was separate from the operating system. If I have time I'll check if there's a jumper on the mainboard for this model tot performance a BIOS reset tot Factory defaults. Another workaround worth trying is to drain the BIOS battery.
le 10.01.2026 23:19
11.01.2026 00:01 - modifié 11.01.2026 09:23
@Akoya321 schrieb:Thank you for answering so quickly.
I If I have time I'll check if there's a jumper on the mainboard for this model tot performance a BIOS reset tot Factory defaults. Another workaround worth trying is to drain the BIOS battery.
None of it would have worked. But one has to save the Bios PW at a safe and easy to recall place. And not forget the safe location. 😁
Bye, daddle
Edit: Typo
