BIOS medion S6426
37 RÉPONSES 37
lms2
Message 1 sur 38
24 340 Visites
Message 1 sur 38
24 340 Visites
BIOS medion S6426
Hi
I own notebook medion S6426.
Last month I visited medion support site, entered MSN number searching for drivers and bios update.
There was listed bios update http://www.medion.com/gb/service/_lightbox/treiber_details.php?did=17813 .
Description says version 2.07, but when I updated downloaded bios, it was version 2.09.
Since bios update to version 2.09, there is no sound from internal speakers or connected headphones.
In device manager, there is no speakers listed, like it should be.
I even tried with restoring to factory defaults and that didn't fix it.
Since this unfortunate provided bios update, about a week later I again entered medion support with my MSN number searching for fixed bios update,
but this time there were(and is) no bios update listed. It looks like medion recognized that it was serving faulty bios update and delisted bios update.
Browsing medion forum, I stumbled on https://community.medion.com/t5/FAQs/BIOS-updates-concerning-the-Meltdown-Spectre-vulnerability-for/...
and again it shows bios version 207, but download bios is version 209
Where can I get bios update to fixed or previous version?
Thank you in advance
Balises (1)
37 RÉPONSES 37
Message 31 sur 38
5 082 Visites
Message 31 sur 38
5 082 Visites
Hi @xomega820,
pls tell us your 8-digit MSN article number which is placed on the bottom case of the NB (3002xxx), so that we at first can identify your unit.
Greets
xomega820
Message 32 sur 38
5 066 Visites
Message 32 sur 38
5 066 Visites
Hi @Major_ToM
Im using the P6685 [MSN: "30025457"], i've seen that the BIOS for the S6426 / S6425 are compatible also for the P6685 / P6687.
Message 33 sur 38
5 052 Visites
Message 33 sur 38
5 052 Visites
Hi @xomega820 ,
checked the manufacturers server and for your specific model the recent version is V 2.08. Future updates can be installed via WindowsUpdate (if there are marked as "critical") or otherwise via the device manager by right clicking on the "System Firmware" and choosing "update driver"
Regards
xomega820
Message 34 sur 38
5 027 Visites
Message 34 sur 38
5 027 Visites
@Major_ToMand theres no way to install Linux? Beacuse I tried but it throws me an ACPI error and eventually the laptop shuts down.
I know that I can use "acpi=off" to """fix""" the problem, but the laptop doesn't charge and the startup it's soooooo slow.
Message 35 sur 38
5 014 Visites
Message 35 sur 38
5 014 Visites
Hi @xomega820 ,
I just didn´t try to install Linux on this machine, but at first it would help, if you would explicitly describe each step you to arrange the installation. What were you BIOS settings, which bootable media did you use, how did you start.. proceed, which specific messages appear on the screen.. kinds of that..
Greets
amon-ra
Message 36 sur 38
3 927 Visites
Message 36 sur 38
3 927 Visites
Has anyone bios 209?, I know that is bugy but is better than actual 208
Thanks in advice
heywire2
Message 37 sur 38
3 915 Visites
Message 37 sur 38
3 915 Visites
Can't send pm, pm me your email or post it here
amon-ra
Message 38 sur 38
3 883 Visites
Message 38 sur 38
3 883 Visites
Xxxxxxxx
Thanks!!!
reply edited to comply with FORUM terms and conditions
37 RÉPONSES 37
