op 09.07.2018 08:48
op 09.07.2018 08:48
Hi
I own notebook medion S6426.
Last month I visited medion support site, entered MSN number searching for drivers and bios update.
There was listed bios update http://www.medion.com/gb/service/_lightbox/treiber_details.php?did=17813 .
Description says version 2.07, but when I updated downloaded bios, it was version 2.09.
Since bios update to version 2.09, there is no sound from internal speakers or connected headphones.
In device manager, there is no speakers listed, like it should be.
I even tried with restoring to factory defaults and that didn't fix it.
Since this unfortunate provided bios update, about a week later I again entered medion support with my MSN number searching for fixed bios update,
but this time there were(and is) no bios update listed. It looks like medion recognized that it was serving faulty bios update and delisted bios update.
Browsing medion forum, I stumbled on https://community.medion.com/t5/FAQs/BIOS-updates-concerning-the-Meltdown-Spectre-vulnerability-for/...
and again it shows bios version 207, but download bios is version 209
Where can I get bios update to fixed or previous version?
Thank you in advance
09.07.2018 11:32 - bewerkt 09.07.2018 12:36
Your given link for the Bios functions, and it shows Bios Version 2.09.
Please give us your MSN-number, because with S6426 (or S6425) no results show up, not in the english and not on the german Medion services pages.
Regards, daddle
09.07.2018 14:10 - bewerkt 09.07.2018 14:15
Someone must have corrected the description, after I sent private message to users: Frog, Major_Tom and DarkKnight and opened this topic
I have proof: printscreen, google cache proof and saved site to archive.org
Am I speaking to an employee of Medion?
I just want posted link to fixed or original(I think it was 2.01 or maybe 2.03?) bios version.
09.07.2018 14:36 - bewerkt 09.07.2018 15:20
No, I am just a helpful user. And you and I don't need proof, I just gave you the info about what I found.
You didn't tell you wrote PNs to the mods.This should belong to the informations given in the first post.
For a Bios-Link maybe @DarkKnight or @Luke can help you therewith.
And your MSN-number? Could be helpful.
regards, daddle
op 09.07.2018 15:05
op 09.07.2018 15:05
Hi @lms2,
As @daddle has already mentioned above, please provide the MSM number of your notebook
and (if available) it`s MD-number.
Thanks in advance,
Luke
op 10.07.2018 16:39
op 10.07.2018 16:39
Medion AKOYA S6426
MSN 30024204
MD 61850
Using ubuntu I figured out problem, and yes bios needs to be fixed
Syslog from my laptop with updated bios
snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
snd_hda_codec_realtek hdaudioC0D0: inputs:
snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
but from my friends medion S6426(same just not yet with updated bios)
snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
In linux I can select unplugged line output(that should be speaker) and sound works with laptop speakers.
Please provide working bios link.
op 17.07.2018 07:36
op 17.07.2018 07:36
Hello @lms2,
I´ve checked your request internally and got the answer that a downgrade to BIOS V2.07 is not possible
due to technical reasons.
Sorry,
Luke
op 17.07.2018 13:59
op 17.07.2018 13:59
Hello @lms2,
A quick addendum on this issue:
After discussing your problem with our technicians we really doubt it`s a BIOS issue. We`d rather
suggest to re-install the respective Ubuntu sound drivers.
Luke
op 19.07.2018 10:11
op 19.07.2018 10:11
Hi.
I have the same problem in the Medion Akoya P6687 - MD61006. After upgrade the BIOS at the latest version (same as lms2 user) the sound stop working. Reading in internet I'm pretty sure that the problem is that the BIOS have disabled the sound card. In Windows the Speakers are marked as "Unplugged".
It is the second laptop of that model the shop have sent me and in both cases is the same. Please, I encourage to Medion to ask InsydeH20 to provide a new BIOS software upgrade that solve that issue.
Thanks in advance.
29.08.2018 18:45 - bewerkt 29.08.2018 18:56
Hello,
same problem here. Before bios update, no sound problems, after update no sound anymore.
*EDIT*
I found the solution, maybe somebody in the future can use this:
Install pavucontrol (sudo apt install pavucontrol)
Open pavucontrol
Go to configuration
And select "Analog Stereo Duplex (unplugged)"
More information on: (works also on 18.04 LTS)
Thanks in advance,
