BIOS medion S6426
37 ANTWORTEN 37
lms2
Nachricht 1 von 38
27.153 Aufrufe
Nachricht 1 von 38
27.153 Aufrufe
BIOS medion S6426
Hi
I own notebook medion S6426.
Last month I visited medion support site, entered MSN number searching for drivers and bios update.
There was listed bios update http://www.medion.com/gb/service/_lightbox/treiber_details.php?did=17813 .
Description says version 2.07, but when I updated downloaded bios, it was version 2.09.
Since bios update to version 2.09, there is no sound from internal speakers or connected headphones.
In device manager, there is no speakers listed, like it should be.
I even tried with restoring to factory defaults and that didn't fix it.
Since this unfortunate provided bios update, about a week later I again entered medion support with my MSN number searching for fixed bios update,
but this time there were(and is) no bios update listed. It looks like medion recognized that it was serving faulty bios update and delisted bios update.
Browsing medion forum, I stumbled on https://community.medion.com/t5/FAQs/BIOS-updates-concerning-the-Meltdown-Spectre-vulnerability-for/...
and again it shows bios version 207, but download bios is version 209
Where can I get bios update to fixed or previous version?
Thank you in advance
Tags (1)
37 ANTWORTEN 37
Mastermind
Nachricht 31 von 38
5.646 Aufrufe
Nachricht 31 von 38
5.646 Aufrufe
Hi @xomega820,
pls tell us your 8-digit MSN article number which is placed on the bottom case of the NB (3002xxx), so that we at first can identify your unit.
Greets
xomega820
Nachricht 32 von 38
5.630 Aufrufe
Nachricht 32 von 38
5.630 Aufrufe
Hi @Major_ToM
Im using the P6685 [MSN: "30025457"], i've seen that the BIOS for the S6426 / S6425 are compatible also for the P6685 / P6687.
Mastermind
Nachricht 33 von 38
5.616 Aufrufe
Nachricht 33 von 38
5.616 Aufrufe
Hi @xomega820 ,
checked the manufacturers server and for your specific model the recent version is V 2.08. Future updates can be installed via WindowsUpdate (if there are marked as "critical") or otherwise via the device manager by right clicking on the "System Firmware" and choosing "update driver"
Regards
xomega820
Nachricht 34 von 38
5.591 Aufrufe
Nachricht 34 von 38
5.591 Aufrufe
@Major_ToMand theres no way to install Linux? Beacuse I tried but it throws me an ACPI error and eventually the laptop shuts down.
I know that I can use "acpi=off" to """fix""" the problem, but the laptop doesn't charge and the startup it's soooooo slow.
Mastermind
Nachricht 35 von 38
5.578 Aufrufe
Nachricht 35 von 38
5.578 Aufrufe
Hi @xomega820 ,
I just didn´t try to install Linux on this machine, but at first it would help, if you would explicitly describe each step you to arrange the installation. What were you BIOS settings, which bootable media did you use, how did you start.. proceed, which specific messages appear on the screen.. kinds of that..
Greets
amon-ra
Nachricht 36 von 38
4.491 Aufrufe
Nachricht 36 von 38
4.491 Aufrufe
Has anyone bios 209?, I know that is bugy but is better than actual 208
Thanks in advice
heywire2
Nachricht 37 von 38
4.479 Aufrufe
Nachricht 37 von 38
4.479 Aufrufe
Can't send pm, pm me your email or post it here
amon-ra
Nachricht 38 von 38
4.447 Aufrufe
Nachricht 38 von 38
4.447 Aufrufe
Xxxxxxxx
Thanks!!!
reply edited to comply with FORUM terms and conditions
37 ANTWORTEN 37
