Akoya P6678 ssd memory
4 ANTWORTEN 4
patpin
Nachricht 1 von 5
200 Aufrufe
Nachricht 1 von 5
200 Aufrufe
I want to put more SSD mem in the laptop. Is this possible; Is there an extra slot of do I have to cnge the ssd; now 256GB ssd. Tnx
Tags (1)
4 ANTWORTEN 4
RAZZ
Nachricht 2 von 5
192 Aufrufe
Nachricht 2 von 5
192 Aufrufe
Hi @patpin
please can you supply the 8 digit MSN number found on the underside of the unit so it can be correctly identified.
thanks
patpin
Nachricht 3 von 5
189 Aufrufe
Nachricht 3 von 5
189 Aufrufe
MSN 300 23 793
RAZZ
Nachricht 4 von 5
185 Aufrufe
Nachricht 4 von 5
185 Aufrufe
Hi
as per unit specs MSN 30023793, your unit comes with 2 disks so you will be ablet to change either one of these.
The SSD will have to be a M.2 2280
Nachricht 5 von 5
180 Aufrufe
Nachricht 5 von 5
180 Aufrufe
@patpin it
I think it would be better just to exhange the boot drive, actual just 256 GB only with a 1 or 2 TB  NVMe M.2 SSD for  SATA III (6 Gbit/s) protocol.
A SSD is much faster than a HDD. But this second drive  is a HDD with1TB, so it could be worthwhile to keep it - or you do replace the 1 TB HDD with a 2.5" SATA SSD in notebook size, 7, 8 or 9 mm thickness.  I think the 9 mm willl also fit in your older NB.
It's all a question of cost.
Edit:
But for Data space, watching videos or keeping music or fotos. the HDD still is sufficient fast.
For exchanging the bootdrive, you have to clone it; in my opinion creating an image is even better,  porting it to the new drive.i
Gives you more data security, also as a backup.
Cheers, daddle
4 ANTWORTEN 4
