le 29.05.2019 14:52
le 29.05.2019 14:52
I have a nas since long time on my local network at home
I can ping and access the nas with local address 19.168.1.2
when I try to connect by internet and medion file explorer : the app does not find my nas
after manual entry with nas-name - user/pw it can not find it
I have already reset the nas for new internet connection : local =ok remote=fail
How can I check my nas is available remotely or how to attack this problem
thanks for all help
best regards, Guy
29.05.2019 15:15 - modifié 29.05.2019 16:11
Hi @przytula
Welcome top the Community.
Do you mean connecting with the Life Cloud App?
This app ist not longer accepted by Google. This could be the reason why it doesn't work.
And the App is not available at Google Play Store since the end of the last year.
Kind regards.
Iks-Jott
le 30.05.2019 00:05
le 30.05.2019 00:05
I once had a similar problem, but now everything is working, I hope that the developers have fixed it.
le 04.06.2019 16:41
le 04.06.2019 16:41
thks for the update
I know the medion app is not available anymore, so I was trying to get remote access by other means
I tried different file explorer on android, that should support NAS
They request you to be on the same network. ok - I am at home and use 192.168.1.2 as address - the same I use for a share in windows.
It does not find this nas through the app
so any idea which app would be able todo so ?
is there a possibility to find out the NAS real internet ip address ?
would it be possible to access the NAS when being on public network - not at home
thanks for all help
best regards, Guy
