URGENT - Need driver Medion akoya e3216
11 ANTWOORDEN 11
donky
Bericht 1 van 12
10.539 Weergaven
Bericht 1 van 12
10.539 Weergaven
Hello
WHere I can find drivers for networking/lan and wifi for medion akoya e3216 which is compatibility with windows 10.
11 ANTWOORDEN 11
Gehringer
Retired
Bericht 2 van 12
8.648 Weergaven
Bericht 2 van 12
8.648 Weergaven
Hi @donky ,
currently Medion does not offer links to drivers and firmwares updates.
It recommends using the update feature on Windows 10 because it makes it easier to find the latest software, firmware updates and new hardware drivers, since It detects most devices automatically and installs the necessary drivers, software and firmware updates when you're connected to the Internet.
Regards,
Gehringer
donky
Bericht 3 van 12
8.646 Weergaven
Bericht 3 van 12
8.646 Weergaven
Thanks for replay
But I can not install from update, I have formated whole hdd and there is no drivers for wifi or lan connections.
Gehringer
Retired
Bericht 4 van 12
8.641 Weergaven
Bericht 4 van 12
8.641 Weergaven
Hi @donky ,
how old is your Akoya? Can you please provide me the MSN number of your product, also?
Regards,
Gehringer
donky
Bericht 5 van 12
8.633 Weergaven
Bericht 5 van 12
8.633 Weergaven
I really can not remember how old it is, think from 2017. But here is msn number: 30023137
Gehringer
Retired
Bericht 6 van 12
8.497 Weergaven
Bericht 6 van 12
8.497 Weergaven
Hi @donky ,
you should be able to find the drivers listed on your Windows 10.
Go to Device Manager -> Network Adapters and then expand this section
Right click on each driver listed and select the "update driver" option
When asked, select the automatic update option, so W10 will go to manufacturer's website and look for the best driver available
Alternatively, your network adapter is the WLAN Intel AC3165 SP AC+BT D2WG, so you can go to Intel website and find the drivers for it.
The link for the UK driver website is here
Please let me know if it has solved the issue.
Regards,
Gehringer
donky
Bericht 7 van 12
8.451 Weergaven
Bericht 7 van 12
8.451 Weergaven
No, and I don´t understand why is there any drivers. I have formated my drive and backup is removed so I can not take factory install. This is NOT old machine and I don´t understand, why there is NOT any drivers which can be used for win10.
Gehringer
Retired
Bericht 8 van 12
8.222 Weergaven
Bericht 8 van 12
8.222 Weergaven
Hi @donky ,
I am sorry but it is not clear to me:
Have you tried updating the drivers from W10 device manager as suggested?
Also, have you visited the manufacturer's website?
Regards,
Gehringer
donky
Bericht 9 van 12
8.150 Weergaven
Bericht 9 van 12
8.150 Weergaven
I have tried everything, windows update is not giving me any drivers. And I have visited the manufacturer's website here on medion only documents to download, which I can not use! Weird and so uproffesionall to remove drivers from it for this model!
Gehringer
Retired
Bericht 10 van 12
8.069 Weergaven
Bericht 10 van 12
8.069 Weergaven
Hi @donky ,
have you checked the link to the Intel website that was suggested?
Regards,
Gehringer
11 ANTWOORDEN 11
