Medion ERAZER Recon E20 HDD/SDD problem!
6 ANTWOORDEN 6
lcaise
Bericht 1 van 7
2.502 Weergaven
Bericht 1 van 7
2.502 Weergaven
Hello,
I bought a Medion ERAZER Recon E20 without operating system (I already have windows 10 home on USB stick).
After plugging the computer into the monitor and starting to install Windows, the installer reported no hard drive. The computer I bought should have two drives
- SSD 512GB
- HDD 1TB
The Bios also does not show the drives, it was only in the "Advenced / Intel Rapid Storage Technology" options that I found that the drives are there but are not "RAID" (see Bios pics). After opening the side of the case, it turned out that yes the disks are in the computer.
Please help, how to make them work ?
Best regards 🙂
337818950_230148509669004_4458511152525380500_n.jpg337919224_766039691588229_2711550508769998135_n.jpg337886021_838618557942100_2718744911813660836_n.jpg337877582_601068161967700_6371836621984856374_n.jpg337907638_795287015207652_25454865007781419_n.jpg337852029_473604361579152_5915667492128955685_n.jpg337977993_746782600220708_2664492234400233280_n.jpg337891433_188726404014440_2802256949636944020_n.jpg
6 ANTWOORDEN 6
lcaise
Bericht 2 van 7
2.498 Weergaven
Bericht 2 van 7
2.498 Weergaven
After entering the serial number on the Medion website, I was taken to the product page and there, from the DOWNLOAD tab, I downloaded the drivers for the head unit (?).
Unfortunately the installation fails...336663768_514121220731599_703675145324457520_n.jpg
Bericht 3 van 7
2.485 Weergaven
Bericht 3 van 7
2.485 Weergaven
 @lcaise
Did you enter the Serial Number or the MSN number? The MSN number entered into the Medion Service page should lead you to the correct product downloads.
Cheers, daddle
lcaise
Bericht 4 van 7
2.479 Weergaven
Bericht 4 van 7
2.479 Weergaven
Hey,
Sure I did this.
Downloaded drivers package and still no success..
Bericht 5 van 7
2.478 Weergaven
Bericht 5 van 7
2.478 Weergaven
@lcaise
OK, but it doesn't give enough information, to say "Installation fails" only.
And the picture is even less informativ.
You should describe the failure and error messages in for most users understandable english.
lcaise
Bericht 6 van 7
2.467 Weergaven
Bericht 6 van 7
2.467 Weergaven
The solution to the problem was to disable the VMD controller, which is designed for Xenons (this is done in the BIOS, under ADVANCED/CHIPSET).
Windows is installed.
Another problem  - I can't get the WiFi module to work, the drivers from the MEDION website require Win 10 1.0.177 and I think I have an older one (BOX version, already installed).
lcaise
Bericht 7 van 7
2.422 Weergaven
Bericht 7 van 7
2.422 Weergaven
Wifi problem solved - downloaded latest Win10 stick-version bootable installer. Works perfect.
Another problem, FireWire card doesn't work properly.
My 2x Presonus Firestidio Project doesn't connect with PC, computer works terrible slow as windows XP with 1GB ram maschine. Even YouTube has terrrible lags.
6 ANTWOORDEN 6
