op 03.08.2016 09:22
op 03.08.2016 09:22
Heya,
I bought myself a Medion satnav from Aldi a few years back, an MD97150. It still works like a charm, but the top clip of the carholder has snapped off. Does anyone happen to have a spare one lying around they dont use, or know where I could get a new one?
op 05.08.2016 08:00
op 05.08.2016 08:00
Hi @Ziptie,
I think this is the holder you need:
https://www.medion.com/medionserviceshop/search?sbf=true&sfs=1&msn=40025524&x=58&y=3
Or did you need the other part of the carholder (the part you stick to the car windows, with the flexible neck)?
op 10.08.2016 08:55
op 10.08.2016 08:55
Hey Bart,
Yeah thats the one I need, thanks mate!
A bit expensive for a bit of plastic, but hey, still cheaper then a new satnav 🙂
