39822members
1135online
139164posts
The Advanced Host Controller Interface (AHCI) is a technical standard defined by Intel that specifies the operation of Serial ATA (SATA) host controllers in a non-implementation-specific manner.
The specification describes a system memory structure for computer hardware vendors to exchange data between host system memory and attached storage devices. AHCI gives software developers and hardware designers a standard method for detecting, configuring, and programming SATA/AHCI adapters. AHCI is separate from the SATA 3 Gbit/s standard, although it exposes SATA's advanced capabilities (such as hot swapping and native command queuing) such that host systems can utilize them.
