Why does the volume of my device change automatically (photo / video)?
Question
Answer
If the volume decreases or increases automatically, it may be because the button is jammed on the remote control or on the device itself. To eliminate the error being on the remote, remove the batteries and check if the volume is now working as it should.
If the volume is still changing, please check if the volume buttons on the unit are operable and not jammed.
Version History
Revision #
1 of 1
Last update:
‎02.10.2019 05:40
Updated by:
Labels (2)
Contributors
