This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customise your cookie settings.
The drum flow sieve must be properly seated in the holder. To make sure, remove the filter and insert it again. The door will only close if the lint filter is properly seated in its holder.
Make sure that the door is not blocked by objects or laundry. Remove the obstacles and check if the door can be closed.
