Where can I find a suitable remote control for my older MEDION device?
Question
Answer
We offer you the possibility to order a suitable remote control for your device via our service shop. Please follow this link: MEDION Serviceshop. Then simply enter the MSN number or model name in the corresponding fields and start the search. If the button "Send request" is displayed instead of the shopping basket, the original remote control cannot be ordered, but you can check whether a replacement item is available. If you are shown that a replacement remote control is no longer available, we will still help you with an alternative solution: You can purchase many replacement remote controls from specialist dealers. If you would like to purchase the item on the Internet, please use an appropriate search engine (e.g. BING). Enter the model of your set and the remote control as search terms.
Version history
Last update:
‎28.10.2021 14:37
Updated by:
Labels (1)
Contributors
