42142members
575online
147554posts
How to reset a Nokia smartphone?
Reset Nokia smartphone with soft reset
Enter the code *#7780#
. Then (if you are prompted) enter the start code 12345
Reset Nokia smartphone with hard reset
If the problem persists, you should try a hard reset*.
Enter the code *#7370#
on your Nokia phone. Then (if you are prompted) enter the start code 12345
Follow the steps below to reset a non-working Nokia smartphone
Press On/Off
+ 3
until the Format option appears on the display.
*Important: Please note that a hard reset completely deletes all data, settings and content on your smartphone and resets it to the original factory settings.
ChangeLog:
Article in other languages:
Review Date: 2025-05-05
