40635members
840online
141446posts
How do I change the interior lighting of my refrigerator?
Set the thermostat control to the 0 position. The unit now switches off. Now pull out the mains plug and then loosen the screw on the lamp cover with a Phillips screwdriver.
Now carefully bend the cover outwards with a flat-blade screwdriver and remove the cover. Replace the defective bulb, observing the technical data in the operating instructions. Now put the cover back on and fasten it with the screw.
Make sure that you only use incandescent lamps with a power of 220-240V, max. 10W. The lamp socket should be E14.
Article in other languages:
Review Date: 04-01-22
