The sound is distorted on my MEDION LIFE E12414 (MD 20018) TV, how can I improve the sound quality?
To improve the sound quality, it is necessary to update the firmware of the device.
You can carry out this necessary firmware update yourself.
The update takes place in three steps:
A) Download the firmware
B) Prepare the USB stick
C) Carry out the update on the TV
⚠️ IMPORTANT ⚠️
Please make sure that every single step of the update process is performed exactly!
With the update all current settings will be deleted.
Proceed as follows:
The USB stick is now prepared.
The update process is now complete.
⚠️ IMPORTANT ⚠️
Do not interrupt the power supply during the update and do not remove the USB stick.
⚠️ IMPORTANT ⚠️
An update of the firmware should only be carried out on the recommendation of MEDION AG.
If you carry out the update without a corresponding recommendation or outside the warranty/guarantee, the following applies:
MEDION AG accepts no liability whatsoever for any loss of data or errors in hardware or software that occur as a result of carrying out the update. The customer acknowledges this when performing the update.
