FAQs on the favorites portal for MEDION Internet Radios
The new favorites portal is now available at https://smartradio.frontier-nuvola.net/
  • How can I install the new online portal?
  • The required website is (https://smartradio.frontier-nuvola.net/). With this you can now manage your favorites.
    To register you need your (username / password).
    Now go to the menu structure, select your device -> Connect new device -> Register radio with code / name (code from your radio: Menu ->. Internet Radio -> Help).
    Now you can activate the item 'share favorites'.
    For the further setting -> tab Favorites -> Manage Favorites -> Personal Streams -> + Personal Streams
    Your personal favorites and podcasts can now be searched and entered as well as (own streams) by URL to the favorites to be added.
  • What should I pay attention to when installing?
  • First, you should check your internet connection of the corresponding radio. You can find the required device ID of each radio at the main menu -> Channel lists -> Help.
    Your displayed device ID is only valid for 10 minutes for security reasons.
    If you would like to register / sign up under an old account of a registered internet radio, you must first log out of the old account.
  • Is there a suitable APP for controlling and navigating my device?
  • Using the UNDOK APP from FRONTIER you have an intelligent device control for your Android and / or iOS device.
    Note:
    The UNDOK APP is not developed and supported by the company MEDION.
    To be found in the respective online stores:
    GooglePlay
    APP Store
Version history
Last update:
‎03.03.2021 08:15
Updated by:
Labels (3)
Contributors
