42313members
683online
147962posts
You can find more information about VIDAA here: www.vidaa.com
In the menu item Select voice control you can select VIDAA VOICE as voice control if you have set up your VIDAA account.
⚠️Note⚠️ Setting up a VIDAA account is required for VIDAA VOICE voice control.
OK
on the remote control. Now select VIDAA Voice and follow the instructions on the screen. When using the AMAZON ALEXA voice assistant, you also have the option of controlling the YouTube app with VIDAA VOICE , as ALEXA is not YouTube-compatible. To do this, activate the function CONTROL YOUTUBE APP WITH VIDAA VOICE under Settings .
Menu
button on your remote control until your TV lists Smart TV Remote in the device list and the message Successfully paired! appears.
⚠️Note⚠️ To use the VIDAA Voice function, an Internet connection and a VIDAA account are required.
To sort the channels, proceed as follows:
OK
on your remote control to open the channel list.OK
.OK
.⚠️Note⚠️ With satellite reception, channel sorting by the user is only possible in Standard mode.
To create a favourites list, proceed as follows:
OK
on your remote control to open the channel list.Menu
button.The information in this article refers to:
ChangeLog:
Article in other languages:
Review Date: 2025-03-09
